Viore PD50VH80 50" Plasma`
  • kevinm34232
    • May 2012
    • 1884
    Re: Viore PD50VH80 50" Plasma`
    Well some progress here found the D5.3V output pins all show a short to ground (around 22 ohms), now I can search for it..
      I can't see a short on the outputs causing no voltage on the primary side, but maybe there's more than one bad component or some test is going wrong.
      That chip you linked to produces standby and main power (15V/5.3V.) Does not produce Vs or Va.
      • kevinm34232
        • May 2012
        • 1884
        Also all the pins on the 'cold' side of the transformer TB801S show a short to cold ground, am I doing something wrong here or is there something majorly wrong. I can't find anything obvious..
          That is normal... a transformer is a bunch of wires around a magnetic core. The wires are wound in coils which are inductive, they have almost zero DC resistance but differing properties when driven at high frequencies, in switch mode power supplies.
          • kevinm34232
            • May 2012
            • 1884
            Ok then, how bout this one then, this 28 pin IC on the bottom, has a short to ground on VSS pins 8 and 19. Could that be it? I don't see a ground pin on that IC though?
              Vss = GND. That is the MICOM for controlling the power supply sequencing. Is strange to see Samsung using a PIC micro, I remember using them in a project a while ago.
              • kevinm34232
                • May 2012
                • 1884
                Great.. lol OK then I dunno I checked all the diodes and transistors on top, and a lot of stuff on the bottom Ill give it one more look then I'm done with it..
                • kevinm34232
                  • May 2012
                  • 1884
                  Would there me any reason that I SHOULD have 24 ohms to ground from D5.3V line or is that definetely a problem?
                    It doesn't sound right, do you have a bench supply? Apply 5V to their and see if a short still appears present.
                    • kevinm34232
                      • May 2012
                      • 1884
                      Actually just got a current limiting power supply, haven't used it yet.. What should I set current to?
                        50mA max for now, 0.05A. Should be enough for the control circuit & not much else.
                        • kevinm34232
                          • May 2012
                          • 1884
                          It seems OK, I set it to 5.3V, but it doesn't let me increase mA over 220. I have the 5.3V at the pins, and I hear the relay clicking when applied.
                          • kevinm34232
                            • May 2012
                            • 1884
                            Tested the cap with 5V applied and still nothing, I ordered a new PS board..
                              220mA should be enough to make something warm very quick.
                              • kevinm34232
                                • May 2012
                                • 1884
                                Well got new PS board today, TV powered up!
                                Had sparkles, had to adjust Vs up a little from 209 to 213, still sparkles. Va is good.
                                Ve says 89 on sticker, getting 101V. Turning VR-VE on X-Main makes no difference in voltage however by turning clockwise I was able to get rid of the sparkles.
                                Not sure this was the correct technique though??
                                  Do you have Yrr/Yfr adjustments? Set Vs back to panel stock or it may buzz more than it should do or shutdown on bright scenes. You probably were adjusting -Vsc at the same time, as they are proportional to each other on these newer Samsung panels.
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Hey Tom, here are all the adjustments..
                                    Vs and Va and were straight forward.
                                    As I said Ve shows 89 on label but I actually have 101V and the turning the adjustment clockwise eliminated the sparkles but did not change the voltage.
                                    Can you walk me thru the adjustments on the Y-Main and Ve? Thanks!
                                    Also I noticed the TV shut off a couple times when first turning on, I wasn't sure at first if I did something or hit the power cord, maybe some voltage is outta whack?
                                      If Vs and Va are too high the TV can sometimes shut off due to excessive power consumption.
                                      Ideal scene test pattern with colour bars, then verification of image retention on scrolling pattern (use service menu.) Finally, verify full white performance and check for pink maldischarge.
                                      Adjustment:
                                      • Set Vs and Va to panel spec.
                                      • Set Vsc (VR-VSCAN) to panel spec.
                                      • Try to set Ve (VR-VE) to panel spec.
                                      • Observe display for sparklies. There are several different types:
                                        • Negative sparklies (stuck dark pixels): Adjust VR-FR first then VR-RR.
                                        • Positive sparklies (flickering lit piels): Adjust VR-FR.
                                        • Image retention (sticking pixels): Adjust VR-RR then VR-FR.
                                      • Should above controls fail to help with sparklies, proceed to adjust VSCAN, VE and VS as below:
                                        • Negative sparklies: Increase VS, VE, make VSCAN more negative.
                                        • Positive sparklies: Drop VS and VE.
                                        • Image retention: Tweak VSCAN/VE.
                                      • On full white scene do you get pink maldischarge? If so, increase VS by a few volts.
                                      NEVER adjust Va, other than to set it to panel spec -- excessive Va kills the panel!
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Ok I adjusted Vs, Va, Ve, and Vsc to panel spec. I was making a mistake and using the Ve pin on the connector instead of the test point, so now I've got everything good.
                                        I had some image retention I played with the FR and RR a little, is there anything other than looking at the picture to those adjustments?
                                        Im watching it now and so far so good I may be done with it! Thanks!
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          There is still image retention when watching something with a fixed image, and then changing the channel you see the image and sparkles for a couple seconds where that image was..
                                          • KYBOSH
                                            VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
                                            by KYBOSH
                                            Got my hands on an relatively unknown TV brand about two weeks ago.
                                            I certainly hadn't heard of it before.
                                            Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
                                            I put it on the back burner until I had so spare time to look it over.
                                            Today was that day.
                                            I plugged it in and was surprised to see that it started up without any issues.
                                            This is an older TV and the most modern video input that it has is DVI.
                                            I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
                                            01-27-2023, 08:19 PM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
